10-22-2019 09:21 AM - edited 01-05-2022 07:41 AM
10-22-2019 10:07 AM
Look at the bottom righ of your screen, click on the ? icon.
10-22-2019 09:26 AM
@Ryannjjohn wrote:I verified my identity and I need a moderator please
Fid you use the green question mark on the bottom right? if so the mods will get back to you. not sure current wait times.
if you send a private message and mods asked you to verify they will be looking at your issue.
10-22-2019 09:24 AM
Just keep checking the mailbox tp right of your screen and a Moderator will contact you via private message.
