04-19-2023 11:15 PM
In the event of needing some CSA assistance do I need 3 different Community accounts?
I am thinking, yes, because during the process the CSA can see that the Community account is linked to My Account and phone number by the same email address that is is used in both accounts.
Also one of the Community Accounts, the posts will not stick. They disappear after a screen refresh. I have contacted a CSA and ticket was created. I was given a 24 hour...we will get back to you. No replies and any follow ups a day apart....no replies. Thus my question .... do I need 3?
I do like the 3 as I can concentrate on community rewards for a specific phone account. I do no self patronizing.
04-20-2023 02:22 PM
04-20-2023 02:17 PM
If I had a IP address block...then my other 2 should not work...but they do. But what I find real odd....is no reply from CSA for an update.
04-20-2023 01:37 PM
Wow....that is weird. So the spam filter discriminates against certain IP addresses? Chock one up to the bizarro world of pm.
04-20-2023 01:35 PM
HI @maximum_gato it does have effect on post level. No red warnings, just the post disappear.
if i remember correct, it has to do with some particular word on the post (except we don't know which word) Because he needs to ask a question (i think about phone compatiblity), no matter how he changed the wordings, it can gone to unmoderated.
I helped him to get a new Rogers IP and he can post that one question without problem
04-20-2023 01:30 PM
His home IP address or did he just happen upon a banned IP address on mobile? I don't believe a banned IP address has any effect on posts being sent to your unmoderated items list. If the IP address has been banned by pm you get a big red warning that you are not allowed access (except with a VPN). Public Mobile can remove the IP ban if done in error....for a home IP address if necessary. If on public wifi using a mobile device then it's temporary until the user changes IP addresses.
04-20-2023 01:18 PM - edited 04-20-2023 01:19 PM
@maximum_gato Yes, learned from experience!!
I thought he got banned. But luckily not. I guess they tried to banned something else by IP and happened to have the same IP (You know with Rogers/Bell, they recycle IPs)
04-20-2023 08:36 AM
Hi @Olive_Oyl
your 3rd account, your posts likely have gone to Unmoderated items.
Try to change up your message and see. If a message has gone to the Unmoderated items, there is no point to copy and paste and post it back
Also, happened to my friend, it could be an IP issue. If you have that issue from home, you can test it by going to some public wifi (like McDonlads, mall wifi, which will give you a different IP) and post and it might work. If that fixes the issue, then somehow the IP was blocked by the Community software.
04-20-2023 08:11 AM
In your post you state "can see that the Community account is linked to My Account and phone number by the same email address that is is used in both accounts." I understand this as you have 2 accounts under one email. If this is correct , each account needs to be a different email address otherwise you may have issues with your service. You would need to contact a CSA agent to have that changed.
04-20-2023 06:21 AM
The 'posts will not stick' issue has to do with rejected items which go into an unmoderated items file.
The most common causes are:
To view your own personal rejected / unmoderated items, click the below link:
My Unmoderated Items - Community (public mobile.ca)
04-20-2023 04:50 AM - edited 04-20-2023 04:51 AM
@BKNS27 wrote:@Olive_Oyl
No you can just have one Community account. You can post questions on their behalf.The only time they need to create a Community account is when they need to contact a CS_Agent with an issue that Community members can’t help solve a problem.
As already mentioned, there is no requirement to create a seperate Community account for each phone number to contact a CSA.
04-20-2023 03:22 AM
@Olive_Oyl
04-19-2023 11:54 PM
@Olive_Oyl wrote:In the event of needing some CSA assistance do I need 3 different Community accounts?
One Community account will do. Some customers do have more than one account, and I have no issue with that unless the person gives bravos and solutions to one's self (or askng fake questions simply to have to have the other account answer it just to get more posts in). A consideration would be that your contributions would get diluted amongst all the accounts. I do see a possible issue if there if only one Community account is being used. If there is more than one ticket open at the same time (for different phone numbers), it's possible that a CSA could mistakenly apply changes to the wrong account.
04-19-2023 11:19 PM
@Olive_Oyl I don’t believe you do need 3 separate community accounts , thou I think it’s advised … asking as you know the credentials for the 3 different accounts you can contact and sort out issues for any of them with one account thru verification of the account phone numbers account number etc
