07-27-2022 05:23 PM
or is there another way to get my account number? Thanks
07-27-2022 07:21 PM
@IsidroFuertes12 - have you ever created a self serve account before? If you activated in-store, you may not have done this yet.
If your account is active, you can register for a Self Serve account here:
https://selfserve.publicmobile.ca/self-registration/
07-27-2022 05:54 PM
When you create your account, did you use the same email address?
Just click on your avatar then click on My Settings and it will show your email address.
07-27-2022 05:25 PM
@IsidroFuertes12 Do you have a rough idea what the email might me? If yes, login to all your known email accounts and look for a welcome email sent by Public Mobile when you activated. If you can't get find that, you will need to contact CS_Agent to get your account verified and get the email information.
Here’s when and how to contact our Customer Support Agents:
07-27-2022 05:25 PM
contact to support team by CS_Agent to change email.
