09-04-2023 04:48 PM - last edited on 09-04-2023 05:58 PM by computergeek541
I need help finding my 12 digit pin for my voucher
edited by computergeek541: change the category label (not reward related)
a month ago
09-04-2023 05:38 PM
here's a bit of reading you might wanna look over...https://www.publicmobile.ca/en/bc/get-help/articles/redeeming-public-points
09-04-2023 05:04 PM
Ok. Your subject line and first question said voucher. That's sends my brain off into that direction. I think you got it figured now.
09-04-2023 05:03 PM - edited 09-04-2023 05:04 PM
@Pringle17 You need to log into your rewards portal to view and redeem them
09-04-2023 05:02 PM
No i don't have a voucher printout i am just trying to convert my points into money
09-04-2023 04:59 PM - edited 09-04-2023 05:00 PM
@Pringle17 Once you have 15 points you can redeem $15 off your phone bill or buy add ons with them also
add pic
Re: Community reward
Great
Points rewards portal view catalog
09-04-2023 04:57 PM
Ok thank you. So what are the public points for
09-04-2023 04:56 PM
Do you have the voucher printout from the store? Do you see multiple sets of 12 digit numbers? If so then use the one labeled as PIN#. Not the one called voucher# even though that would make sense.
No you can not buy vouchers from points. You can convert your points into "money" into your account here though.
09-04-2023 04:55 PM
@Pringle17 No unfortunately. Vouchers have to be purchased from 7-11 shell gas Canadian tire or recharge. .com or musk bird
09-04-2023 04:53 PM
Can i use my public points to get my voucher
09-04-2023 04:49 PM
@Pringle17 It should be printed on the voucher you have purchased and add it *611
