12-22-2019 11:53 AM - edited 01-05-2022 08:39 AM
12-22-2019 01:58 PM
12-22-2019 12:52 PM
12-22-2019 12:39 PM
@popping wrote:
@popping wrote:Is your router configure to filter out MAC address? i.e. only allows device with the pre-defined MAC addresses to use your wifi.
Are you running WiFi manager app such as Wi-Fi Privacy Police on your phone?
NETWORK_SELECTION_DISABLED_ASSOCIATION_REJECTION=1
Google NETWORK_SELECTION_DISABLED_ASSOCIATION_REJECTION for more info.
12-22-2019 12:24 PM - edited 12-22-2019 12:29 PM
I suggest you do as popping said, i.e. Google it - there's LOTS of info about that problem, including some videos.
12-22-2019 12:20 PM
Any chance your phone is a recent acquisition, and the router has been configured to allow a certain number of devices to connect, i.e., for instance, the household had 5 devices to connect, so whomever configured the router set it for 5, and then you got a phone and can't connect, because that would be device #6?
There's also a possibility that the router has a security protocol in use that your phone doesn't use, i.e. maybe your phone is old???
Lots of possibilities, and not enough information.....
12-22-2019 12:14 PM - edited 12-22-2019 12:20 PM
12-22-2019 12:07 PM
Have you tried doing a forget network on your phone with the WiFi ssid that you're having issues with?
12-22-2019 12:06 PM
I don't know...I will have to check
12-22-2019 12:03 PM - edited 12-22-2019 12:14 PM
12-22-2019 12:02 PM
Ok, but that is not happening for me.
12-22-2019 11:58 AM
I have restarted the router several times, everything else in my house connects and has wifi but my phone. I have attached a pic of what my phone is saying when it won't connect.
12-22-2019 11:55 AM - edited 12-22-2019 11:57 AM
@PauladIf you can't connect to your wifi, have you tried restarting your router/model/phone? Your post is blank, its only the subject.
This really has nothing to do with public mobile, but maybe we can help you. Can you give some more details of what hardware you have, and what is currently on the network (what service provider, what router, other computers, tablets, etc) and their status? What is the exact error you are getting and from where?
12-22-2019 11:54 AM - edited 12-22-2019 11:55 AM
You don't get the IP address until you sign in to your wifi
