I cannot RESET password
cira777
9 REPLIES 9
BorisDoris
@cira777 wrote:
No worries, all good now.. thanks
What did you or agent do?
cira777
HI @cira777   No.  Support is fully online here
Please open ticket quick if you need this resolved sooner.
It sounds different, but it is not bad.  You open a ticket , you just come and check the inbox every 15 mins instead of on hold on the phone for the full hours
cira777
There is no phone number to call?
cira777
It does not let me Reset Password... seems they disabled my account
HI @cira777   If it is just locked, it has been over an  hour and if you tried, it should work now
Look like you need the password reset.  Please follow the steps above to open ticket.  CS Agent will reply via Community inbox .
cira777
My account was locked... I cannot reset the password.. please help
HI @cira777   Did you try Reset Password already and unable to enter the correct email address or not able to answer the security question?  If that is the case, please open a ticket with PM Support to have your password reset  at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. First type: "Forgot log in information"
  2. Then Click "Contact Us"
  3. Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
Yummy
What is the issue? Too many attempts? Then wait 1hour before trying again with correct password. If it does not work contact agent for assistance:
To contact CSA-agent, there are 2 methods:
