I can't send or receive text messages
Mmehrz
My mobile has dual sim
I was overseas and used a local number in Sim 2
Since I came back to Canada and
I am not able to send or receive text messages
I checked the settings and the message centre is "+16475800172"
Not sure what is the issue
Cheetah24
@Mmehrz: What do you get when you try to send a text message? Any error? Also you are able to make phone calls correct?
Mmehrz
I removed the other Sim
Only public sim is in the mobile
@Mmehrz  Check the sim manger in your phone settings and ensure PM is enabled /set to primary . And the overseas number is not enabled or set to primary and reboot the phone see if that helps
