I can't make calls or send text messages
RutaN
I can't make calls or send text messages, My account is up to date and I rebooted the phone several times
RutaN
Thanks just did it.
@RutaN  Please message support to investigate then
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
RutaN
I can't call *611, reboot doesn't work, online I see that my account is active
@RutaN  Call *611 or log into account is it active or on hold ? If active can you reboot the phone or reset network settings . Or if possible try SIM card in another phone to test services .
