I bought a add-on, 3G and unlimited talk 15 d for $30. But it doesn't work! Need immediately help.
pingzh88
I bought a add-on, 3G and unlimited talk 15 d for $30. But it doesn't work! Need immediately help. Now in USA
17 REPLIES 17
Pingzh
This advice works! Thank you!
Pingzh
This is a good advice! Thank you all  the community!
Pingzh
Thank you! Works now.
Did you scroll up and review all the replies from your last experience? Which exact add-on did you buy? Data? Or one of the bundles? Do you know if the phone has been enabled for volte yet? Are you able to manually switch down to 2G GSM?
Pingzh
This is my 2nd Add-on. First was few month ago. This time, data and txt works, but can make and receive calls.
Pingzh
I bought with my credit card online. Data works but talk doesn't work.
Pingzh
@pingzh88  We happy you got it all sorted out , enjoy your visit 🙂
pingzh88
Yes. Thanks.
pingzh88
Working. Thank you!
@pingzh88
So was the solution to your described issue to connect to the T mobile net work as you have chosen?
@pingzh88
Auto pay can fail
To make payment and reactivate plan .. if you know PIN number you can *611 with a voucher and *611  no PIN needed . You can also do this by by calling 18554PUBLIC . otherwise log into self serve make manual payment and reactivate service and or update credit card if necessary
My account
Legend  and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
If you  still have service and your plan renews today / tomorrow you can ignore this suspended notice
@pingzh88 wrote:
Yes, Tried to use data, it asked to buy....can call and talk, but after a call, just been suspended
Also, ensure your plan is in Active status. Addons only work on Active plans.
pingzh88
@pingzh88 - is this your first or second addon you purchased? And if talk and text work, ensure you have data enabled on your device to use the data portion.
If first time buying this, try restarting your phone or perform a reset of the network settings to help get connected.
If this is the 2nd time buying this after your first one expired, the first one may not be fully expired yet. Plus you need to wait another 12-24 hours after it expires to buy the same addong (silly, I know). OR, buy a different bucket of roaming addon...
If you want the 2nd $30 to work, submit a ticket to CSA to have them activate it for you.
­­­Public Mobile Representatives customer support­­­ agents (CSA) can be contacted by either two methods, found here:
HALIMACS
@pingzh88
due to the decommissioning of the 3G network in the USA, in order to use the talk feature of roaming add-ons, you need to set your device to the 2G setting under the device’s Network Connections or Cellular.
For devices which do not have this option, your calling will be impacted.
@pingzh88  Make sure your connected to T mobile and reboot the device
