Husband's debit card expired! Email/password not working to open account again with new debit card.
Flash51
1 REPLY 1
@Flash51
the My Account login username is an email address
First try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
if not, PM support will be your friend then, please open ticket with them
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
