07-13-2015 03:19 PM - edited 01-04-2022 01:46 PM
I have a Samsung Galaxy Model ACE II x cell phone with Public Mobile. The phone operation is continually being interrupted with my Yahoo E Mail and Face Book Notifications (Downloads / Sounds / Vibrations etc.). How can I reset the SETTINGS on this phone to stop / eliminate this problem? I have discussed this problem with Public Mobile and received NO GOOD SOLUTION! I have also sent an E-Mail to Samsung Canada describing the problem with NO FEEDBACK to date. I am open to any suggestions to try to solve this problem! THANKS
07-13-2015 06:24 PM
07-13-2015 03:45 PM
07-13-2015 03:36 PM - edited 07-13-2015 03:39 PM
Hello,
It seems that the problem is with the apps. Public Mobile didn't put them on your phone.
The solution is to turn off notification by the apps. One way, if possible, is to go into the settings of each app to see if notifications can be eliminated.
If that is not possible, uninstall the apps from your phone.
If that is unacceptable to you, then the solution is to live with the current situation. I know that you were hoping for a better solution, but that is the fact of the matter.
