How to reactive voicemail
NancyHePub
Hello, I have accidentally disabled my voicemail a few years ago. Now I want it back, please help!
NancyHePub
Thank you!
NancyHePub
Thank you very much!
I just find out that I have put an extended absence greeting and chose the option not allowing leaving messages. Now, I’m able to receive messages.
HALIMACS
@NancyHePub
To reset it back to defaults, try dialing ##004#
dust2dust
Did you ask support to disable it for you somehow? I don't remember there being a way to disable it.
Can you get to voicemail when you dial 1-778-580-4001?
