How to find how much data I used in total in the last 30 days?
whatsgonewell
I go to Overview/  then to My Data & Add Ons .. and saw no mention of current data used
what happens if this data-used is not displayed?what happens if this data-used is not displayed?
In my son's account this use of data is now visible in this meu. Why?
Namemee
I don’t think it will show the data allotments for every 30 days because it is a 90 day plan. For my 30 day plan it shows as Active Status; and it resets to 0mb when the 30 day is up.
Alex888
Look under My Plan and click where is says View My Usage, you can see a list of all calls text and data you have used and can specify start and end dates.
NDesai
@whatsgonewell It's right there. "662.883 / 3072 MB".
EDIT: i think i might have got the question wrong.
If the line item disappears then you've used your allotment. It will re-appear at renewal.
