05-25-2017 11:28 AM - edited 01-05-2022 02:07 AM
I have noticed that I have to relogin to the community, on a daily basis or sometimes after closing my browser, ( I check the keep me logged in button).
Was wondering if anyone else has this issue? running windows 10 and chrome. Anyone know How long are we supposed to be kept logged in?
05-25-2017 11:59 PM
No such problems here. I use chrome and dolphin on the phone, seamonkey and firefox on the PC. In all cases, I accept cookies and saving password. Anytime I go to the forum, I am logged in. That said, there could be some glitches in this portal that is causing certain accounts to be logged off. RFD which I am a member of had major issues with logins about a month ago. Never mind losing the ability to stay logged in, it would not even allow a manual login. After some failed attempts, a password reset was recommended and the reset would not work. It turned out to be a server issue.
05-25-2017 03:43 PM
are your cookies set to auto clear?
if so disable that and you shouldnt have a problem
05-25-2017 01:48 PM
I usually have to login again when I get on a different wifi network. If I stay on the same wifi then I stay logged in almost forever.
05-25-2017 01:44 PM
05-25-2017 12:24 PM
@mimmo - for me it depends on what I am using....
Chrome seems to never log me out.
My iPad needs to be logged in everytime I close the browser.
05-25-2017 11:42 AM
I've had it happen every few days or so. But right now it appears I can stay logged in for a decent amount of time.
05-25-2017 11:41 AM
I dont seem to have that issue. I usually stay logged in for quite a long time.
05-25-2017 11:32 AM - edited 05-25-2017 11:33 AM
