09-19-2021 09:59 PM - edited 01-06-2022 03:34 AM
09-20-2021 01:28 PM
first try to Forgot your password Here link, and enter your email address,
or Explain your issue to Contact Customer Support Agent by CS_Agent ,
they can solve your issue, they are nice Service Team they will help you 100%.
and they will Reset for you,
Here’s How To Contact Customer Support Agent by CS_Agent,
Good Luck....
09-20-2021 12:41 AM
PM self-serve system is down for maintenance at the moment.
@yadams If you had not reset you password reset link on the login page earlier, try it in the morning.
You need the answer to your security question in order to reset your password.
09-19-2021 10:19 PM - edited 09-19-2021 10:20 PM
@yadams wrote:answer please
try Forgot password link. If would tell you right a way if you have the correct email address. Try all the email you have and see which one works. But after you get pass the email address, you will still have to answer the security question after
In case you still cannot reset the password that way, you can open a ticket with PM CS Agent and have them sort out for you
To open a ticket with Customer Support Agent, click on the Bubble or directly at : https://publicmobile.ca/chatbot
type: Forgot log in information
Click "Contact Us"
Click "Click here to submit a ticket"
After ticket successfully opened, keep checking your Community inbox (envelope icon on top right) CS Agent will communicate with you there
If you have problems submitting a ticket, you can also send a private message to CS_Agents (but this can take longer):
09-19-2021 10:05 PM
@yadams : If you've already set up a self-serve account, did you try the Forgot your password? link?
09-19-2021 10:02 PM
answer please
