2 weeks ago
I’m planning to go on a trip to US and buy the US roaming data soon. How do I track the usage of the US roaming data tho? Thanks in advance.
2 weeks ago - last edited 2 weeks ago
Oh ok thanks, have you done it before? Is it possible to choose LTE either or 5G? I also wonder if it’s going to be 5G same as the data I’m using in Canada.
2 weeks ago
hi @Soyul Welcome and have a fun trip. Make sure you understand you need to turn onobile roaming data, and try to connect to At&t or T-Mobile, and you might need to manual connect to them. And try using LTE and definitely not 5G
2 weeks ago
Ok, thanks
2 weeks ago
Thank you
2 weeks ago
I would go to the app store and check out data usage apps. The Public Mobile app updates twice a day. Depending on your phone, you may be able to monitor data usages without any apps.
2 weeks ago
hi @Soyul download PM app and it will break down the US data usage
also, once all used up, you will still getting data, so no worry about extra $ for overuse
