How do I activate Auto Pay?
lstead
HALIMACS
Hi @lstead
Refer to this link for a Help article from Public Mobile:
Set up AutoPay (publicmobile.ca)
(EDIT:  which is copied/pasted above by @Triguy 😁)
Triguy
To set up AutoPay, sign in to your Self-Serve account, select the ‘Payment’ tab, then ‘Register for AutoPay’. From here, you can sign up for AutoPay or remove the feature, if you no longer want payments to automatically occur. If you would like to change the card that is automatically charged, scroll to the bottom of the ‘Payment’ tab, then select ‘Manage my card’. This will allow you to update or remove your credit or Visa Debit card.
kb_mv
@lstead Go into your self serve account. Click payment tab at the top. Ignore the red arrow Click Manage Autopay.
Edit: As noted by @Triguy , it will say Register for Autopay...
