08-09-2023 03:58 PM
My son is on an international exchange. I can' log into his account to pause it for 90 days because it requires a code sent to his phone. But he can't receive messages on the number attached to his SIM card because he's in Switzerland. Please help!!
08-10-2023 09:48 AM
Resetting the password worked. Thanks!!
08-09-2023 04:01 PM
if you know the 4 digits account PIN, then call 1.855.4PUBLIC , enter 1 for Englsh and then the phone number. You can then disable Autopay there.
if you do not remember the PIN, . you can s til login to My Account but you can ask the code to send to email instead
On the screen it is expecting you to enter the code, click Didn't get the code? or Resend code and then choose Send email
If you have not created an EverSafe id yet, you won't be able complete the part to link your My Account with the EverSafe ID, that needs a working phone with a working PM sim using SMS. (Sending the code to email would not be a choice until EverSafe id is fully setup)
Try these workarounds, it could bypass the SMS in linking My Account with EverSafe ID
If none of those workarounds helps, please open ticket with support by direct message here:
