Hollow voice
donberkeley
My voice sounds hollow but if i put it on speaker it sounds fine ?
chris_chan
I don't have that problem and I've had Public Mobile for over two years. It's mostly likely the model of your phone itself rather than the Public Mobile service.
@donberkeley  - do you have your bluetooth setting enabled? If so, try disabling it and see if quality improves.
Other things to try:
-disable noise cancellation (if applicable)
-ensure you have the latest software installed
-rebooting your phone
-toggling in/out of airplane mode
-try using the phone without the case
-performing a reset of your device's network settings
@donberkeley
Phone Info by Samsung is another good app to check your cycle numbers.
.. .if you want to check Battery health on Android, try AccuBattery.
@donberkeley
Check your battery health, it could happen if it is less than 80% on iPhone.
Androids does not have battery health setting but if you have charged over 500 cycles or more than 2 years…it is your phone most likely.
Try putting the SIM in another phone to check.
@donberkeley   that would likely mean a problem with your phone instead of the network.  Did you try to put your SIM in another phone?  try to get a spare phone from friend and test it out
