Galaxy Note 9 Exynos Compatibility
B12
Hello,
I'm very interested in getting a Galaxy Note 9 device. I'd like to get the Exynos variant as the SD variant locks the user out of being able to properly use the device. ANY WAY, I looked at GSM arena and it claims that the Exynos variant has the 850(maybe not this?), 900 & 1900 bands required by PM. Can anyone confirm this?
@B12 wrote:
Yes, unlocked. I never buy locked. 😁
@B12
great,,
glad to hear that,,
and Good luck..enjoyed....
B12
@B12 wrote:
It's this one, should work no problem.
https://www.gsmarena.com/samsung_galaxy_note9-9163.php#n960f-ds
@B12
 is it a unlocked right, if so don't worry about it and Yes is will working with Public Mobile 100%
B12
@B12 which regional model is your Exynos? What exact model number?
I think we can say it should work.. Most Samsung model, especially flagships like this one should work on PM.. even missing the 850, there are  other usable bands
Give me the exact model number and will try to look up what bands on this phone.
@B12
Yes is will working with Public Mobile.
visit Here link to you can check it full information about your device.
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
