02-24-2022 11:12 AM
I recently (Jan 19th) activated PM accounts for my self & my wife using a friend’s code for both. There was a problem with the activation & our numbers were not ported correctly, which has now been resolved. My friend never received his awards for our activations.
02-25-2022 03:33 AM
So you activated your pm accounts on January 19th it was just the porting in of your phone numbers that was delayed. An important distinction as it puts both of your account's under the old rewards system not the new points system which is much less rewarding. Just thought I would point that out. Stick with rewards.
Since neither of your account's recieved the $10 bonus credit nor your friend the 2×$1 reward then you fell victim to the glitch that started to occur about 6 or 7 months ago that despite entering the correct referral code at activation it simply does not register on the account. As you have already contacted customer support to rectify the situation your friend will see the 2×$1 rewards added to their rewards account immediately after the referral code is added to your two accounts. The $10 bonus referral credits will appear in your account's within 72 hours but likely the next day.
02-24-2022 09:32 PM - edited 02-24-2022 09:33 PM
@BKNS27 Not both. PM would like to ONLY the referee open ticket with PM
From our friend S-S ( Simple-Simon):
02-24-2022 09:22 PM - edited 02-24-2022 09:22 PM
I guess the CS_Agent will know who the referrer code belongs to.
Just covering all bases incase the referrer doesn’t get their reward.
02-24-2022 09:01 PM
02-24-2022 06:08 PM
@hTideGnowThank you very much for reminder!
02-24-2022 03:54 PM
Hi
No, did not get $10 credit. I can’t recall if I clicked add button, but regardless, the phones weren’t even activated. It took another 3 weeks for the problem to be resolved. I’m thinking that was the issue. I have taken it up with moderator today.
02-24-2022 03:52 PM
02-24-2022 03:51 PM
Yes, thanks. Have done today.
02-24-2022 03:27 PM
@expatpapa : Still no update from you on whether you both got the $10 credit. Did you click the Add button when you entered the referral code? If so did it give any indication of being successfully entered...if you recall of course.
02-24-2022 03:24 PM
Both you and your friend should contact a CS_Agent to help rectify your issue.
02-24-2022 03:22 PM
Hi
No, nothing like that received. He is familiar with the system, as has had several rewards in the past.
02-24-2022 12:54 PM
Ask your friend if he sees something like this on his account:
if not then referral code was not properly applied.
02-24-2022 12:24 PM
Check with your friend’s referral code. Sometimes the zero is put in with an “O”…common mistake.
02-24-2022 12:19 PM
Thank you for the response. I have submitted a ticket to moderator to try & resolve.
02-24-2022 11:28 AM
HI @expatpapa You see the $1 extra from referring your friend on My Rewards site? With or without porting issue, your friend should see the $10 within 72 hours
Have your friend to open ticket with PM support. Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
02-24-2022 11:24 AM
Your friend can also check their Self Serve account under My Rewards and they should get $1 off/phone number referred with last 4 digit and you & your wife should have got $10 credit in your account.
02-24-2022 11:22 AM
@expatpapa Well really you should have used your friends referral code for just one account than used that account's referral code for the second account so you would have collected savings. Unfortunately to late for that now.
As for your friend. When you used the referral code to sign up. Did your friend get a "Caching text"?.. Has your friend logged into their reward section to see if there is anything displayed next to referral reward?...not sure if he is on old reward system or new points system. Old rewards he would get $1 per account he referred and point system would be 1 point per referral. They don't get that instantly. It displays under the reward section until it is their renewal then the system credits it.
As for you n your wife you'll get a $10. signup bonus each. It takes up to 72 hours from activation for it to be credited to your account.
Check with your friend if they got a text or are the rewards. Thanks.
02-24-2022 11:19 AM
But did YOU both get a $10 credit? If so then a valid referral code was entered. If not then not.
02-24-2022 11:19 AM
Your friend will need to contact a CS_Agent explaining the problem. They can contact them by private messaging on top of this page or the Chat button on the bottom right of this page and type in Create a Ticket.
