08-19-2023 05:29 PM - last edited on 08-19-2023 06:45 PM by computergeek541
Hi Everyone,
My friend wants to subscribe to Public Mobile and is asking if his previous phone number from another provider (rogers) can be transferred over to PM.
Thanks
08-19-2023 06:47 PM
@khoat wrote:My friend wants to subscribe to Public Mobile and is asking if his previous phone number from another provider (rogers) can be transferred over to PM.
Without knowing which city the phone number is from, no one here can accurately answer this question. There's a requirement that both involved carriers must both other phone numbers for that same location.
08-19-2023 05:38 PM - edited 08-19-2023 05:39 PM
@khoat Yes your friend can transfer the number on activation . Or pick a temp number with PM and then transfer afterwards . Just remember to keep old providers sim in the phone so you can reply YES to the confirmation text to transfer number from old provider . Then wait for that sim to stop working usually with in 20 mins to 2 hours and then put in the PM sim and you’re good to go . And don’t forget to use your referral code
08-19-2023 05:33 PM
Have your friend check here.
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do?lang=en&appname=otherportal
08-19-2023 05:30 PM - edited 08-19-2023 05:31 PM
Yes. As long as his Rogers account is still active he can port the number. If the account is closed, nope. It's gone.
EDIT: Make sure he enters your ref code correctly. Also, keep an eye on it to make sure you're credited. Sometimes mistakes happen.
