Free 2GB data and 500 minutes int'l long distance
Lai
Last Saturday I answered YES2 to the above-mentioned season offer and was told it had been added into my account but when I checked now, the offer wasn't added into my account. What I have now are the previous years' offers
8 REPLIES 8
Guspublic1
Just login on ur phone and
Its there, you have to click on the little circle inside where it says Refreshed 2 minutes ago or something like that
Click on all 3 circles with arrow on it to refresh on screen. It will then show  bonus minuets and data
Guspublic1
Coverhiro
@Lai Similar thing happened to me.
I missed the opportunity to reply YES2.
I got another message from them before I had the chance.
So what I did was contacted @CS_Agent and they fixed it easily by applying it to my account and I was able to verify with them before my ticket was closed. Easy peasy.
or contact them through here
Lai
Meow, I don't have a computer
Meow
Public Mobile has web page cache issue so you might be looking at obsolete status. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
Outdoorsman
@Lai
hi use a different browser in private or incogito mode and sign back in to see if it updates for your 2 gigs and minutes
dabr
@Lai   Try logging into the account using incognito/private mode as it's possible you're seeing an older cached account page.   You can also try refreshing the page by clicking the refresh icon bottom right of the account.
Quigley
@Lai
Try logging into your account using a browser in incognito or private mode first.
Your probably looking at old cached information before.
