Forgot password and security question
Harbani
I forgot my password and security question
7 REPLIES 7
treefrog
@Treva_1969
Just use the question mark at the bottom right corner of your screen and talk to the Chabot named Simon for a service request or send a private message using the link a couple if posts before mine. Just make sure you include your name, address, email, phone number and pin.
@Treva_1969 Did you read this thread before posting? The answer is there.
Treva_1969
i fotgot my password and my securty question not working
@Harbani wrote:
I don’t see question mark in right corner
Click on Get Help up top and muddle your way through the chatbot from there.
Harbani
iliketotalk
@Harbani try contacting a moderator you can do so by clicking the question mark at the lower right corner,to avoid going around in circles with Simon say that you want a human to speak to, a ticket will then be generated briefly mention your issue, you should get a response between 2 to 48 hours a reply should show up in your little envelope in the top right corner in the meantime is there anything that we may be able to help with?
kselmak
Please contact mods https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Be ready to prove you are the account owner
