Flip phone - incoming calls do not ring or show in call log, outgoing calls and voicemail work
Cath
This has been happening with my Coolpad Snap for a few weeks and working with Coolpad tech support has failed to resolve the issue.  Today, my husband informed me that his Alcatel Go Flip has the same issue.  Settings on both phones have been checked.   That this is happening on two different phones with two different Public Mobile plans makes me wonder if it could be a PM issue.  Does anyone have any bright ideas?
Thanks
EDIT
Sincere thanks to everyone who responded.  Hub and I can call each other and the phones ring!  These two seniors, 80 and 79, are soooo happy!
One final question:  can I mark two replies as solutions?
19 REPLIES 19
Cath
@t_p
No option for WCDMA
Only options are:
LTE On (Automatic LTE/3G/2G)
LTE Off (Automatic 3G/2G)
2G Only
I selected LTE Off
Thanks
Cath
@S--S
Thanks for the reminder.  I totally forgot to reboot.  As my son tells me, “Keep up with the tour, Mom.”  😂
dabr
@Cath wrote:
@dabr
For two seniors on a very limited budget, even one refurbished smartphone is not possible.  But thanks for the info. 🙂
@Cath    Of course, if finances don't permit purchasing even something like the refurbished Moto E/$99 which is a good phone at a reasonable price, then perhaps there's some family or friend who may upgrade their phone soon and is willing to to donate their old smart phone to you at no cost?   I was using a hand-me-down for a couple of years, although I already a smart phone, it was an improvement from the one I had.
Anyway, hopefully, you can get the issue resolved and are able to get another year or more use out of your flip phones .  Good luck.
t_p
@Cath wrote:
@t_p
No option for WCDMA
Only options are:
2G Only
I selected LTE Off
Thanks
That's strange. My Go Flip has that setting.
@Cath   what area (province and city) you are at?
And those missed  calls went to VM?   All incoming calls are like this or just half and half?
@Cath
Thats the right setting. Have your husband call you.
Cath
Am in Owen Sound, Ontario.  Problem seems to be resolved now, thanks to settings suggested by @darlicious and @t_p .
0PX9O4
So glad this issue could be resolved for you both @Cath !!
t_p
Thanks
EDIT
@Cath
No, you can choose only one.
Personally, I think @darlicious deserves the honor since she suggested the solution to you first.
pkaraa
No, you can choose only one as accepted solution.
you can bravo others.
