09-01-2023 09:48 AM
I wanted to know if i choose the plan, would i still get my Public Rewards discount? I was about to check out but when I went to submit, i noticed there was no public reward discount applied ( i have $7 dollars a month so should be 21 off).
09-01-2023 10:26 AM
yes. and thanks.
09-01-2023 10:24 AM
you used Change now?
If Change Now was used, your regular rewards discount will be credited to your account as Available Fund within next couple days
09-01-2023 10:14 AM
I just changed my subscription but I'm still not seeing my discount. is it going to be updated later?
09-01-2023 10:00 AM
Thx!
$1/ month. how do i get your plan? lol
09-01-2023 09:55 AM
changing plan won't affect your rewards. So, you will still be on the old rewards program and hence will be getting rewards discount and not Public Points
For the $39/month 30 days or $34/month 90 days plan, sorry, you can change over to that too now. So, hand over to change plan page and schedule a plan change before it is gone
https://myaccount.publicmobile.ca/en/account/plan/change-plan
09-01-2023 09:53 AM
@vincent1990 Yes you will keep you old rewards I can confirm this . I too just switched my plan and kept my old rewards here have a peek
09-01-2023 09:52 AM
what if this isn't a new activation?
also, i'm with the old rewards program not the new point system.
09-01-2023 09:50 AM - edited 09-01-2023 09:56 AM
Yes, you will get Public Points rewards on all spending you have with PM regardless of the plan you have
And again, this $34/month 90 days plan is for new activation only. When you activation, please download the app and start the activation from the app
