08-20-2023 08:53 PM
I just checked my rewards, things getting worse: redeem 1G data needs 15points ( before needs 10 points ) and only good for 15 days.
08-20-2023 09:10 PM
Thanks 😊
08-20-2023 09:04 PM
@Lhaha No worries @computergeek541 already has . And just so you know you can edit your reply by tapping the down arrow by the time stamp in the post you want to correct
08-20-2023 09:02 PM
Sorry I was going to chose your answer as the solution but I pushed wrong button, hopefully they could change it
08-20-2023 09:01 PM
@Lhaha wrote:I pushed wrong button for solution !!!
I've made the correction.
08-20-2023 09:00 PM
08-20-2023 08:58 PM
Thanks, you were right 👍
08-20-2023 08:54 PM
@Lhaha You may be looking at the US roaming add on it’s for 15 days . Regular data add on is for 30 days . Have another look
