2 weeks ago - last edited 2 weeks ago by computergeek541
I activated in March 2024 and from the beginning I could not send MMS pictures due to an apparent error in the Public Mobile APN. The correct settings are as follows:
APN Name: PC Mobile
MMS proxy : mmscproxy.mobility.ca
MMS port : 8799
Be sure to save your updated settings. In my case, the changes were immediate; I did not have to reboot/restart. I am now able to send (and receive) MMS pictures.
Sunday
Just wanted to add: APN Name: PC Mobile is just a descriptive name; you can change this to "Public Mobile" or "Go Canucks" or whatever works for you. The detail settings have to be correct.
a week ago
After making manual changes to my APN and saving them, the changes were immediate without need to reboot or restart my device.
a week ago
@fixin1 Thank you.
@Phil_Adelphus : I am in the right community. I ported to PM from Telus. I have never been on Koodo nor Bell or any of it's sub-carriers such as PC Mobile. PC Mobile has relationships with both Bell and Telus.
Both after porting, and after a CSR recent reset of my network settings, I had the following APNs:
[Koodo] - sp.koodo.com - it has incorrect settings which disallow any Data.
[PC Mobile] - sp.mb.com - it has partially incorrect settings which did allow Data but not mms.
[Telus] - sp.telus.com - it has incorrect settings which disallow any Data.
Please note the [bracketed names] are merely user-friendly descriptive names.
I did not have the [Koodo] or [PC Mobile] APNs when I was on Telus. I suspect because I have a non-standard (in Canada) Android device, Public Mobile incorrectly identified it and sent me the wrong APNs. Telus had a relationship with PC Mobile, so that may explain why the PC Mobile APN was included.
After correcting the settings, I can for now send and receive MMS pictures, so issue is happily resolved.
I have contacted CSR and asked them to forward the matter to Technical Support for their review.
@CatalystOne This is Public Mobile (Telus) but your post is about PC Mobile (Bell) as @fixin1 noted. Telus changed the APN for MMS back in February, here is some info including links to the correct APN for both iPhone and Android. The change did not affect all devices, it was mainly older ones, there is a list in the FAQ of compatible models.
https://www.publicmobile.ca/en/on/get-help/articles/picture-messaging-updates
If the PC Mobile APN worked for you maybe you're in the wrong community, did Bell change APN settings for MMS too?
2 weeks ago
@CatalystOne - That APN seems to be PC Mobile
Next, check your APN settings (Android Phones Only):
