Error during transfer and porting cell number
caoxying
Hi there!
I need your help!
I have made an error during the transfer and porting cell number. I mistyped my current cell number by 2 numbers. Is it possible to retrieve or fix the number?
Thank you!
2 REPLIES 2
@caoxying   no worry, there is a team you can call and talk to live support.  You can update them with the correct information.  I will privately message you the phone number.  Please check your Community inbox and call the line to get it fixed
Try again and leave your old SIM card in your phone until you receive a text confirming the transfer @ that point you simply reply YES and you will have 90 mins to do so once you receive text from old carrier
