Enter my account
Bluegrasser
Need to give new info  for payment
8 REPLIES 8
Bluegrasser
I'm paying with vouchers tha I pay for at Canadian tire
@Bluegrasser
If you have been in nonpay/suspended status for over 90 days, then you lost your Public Mobile account, phone number, and access to self serve.
Otherwise, see other posts for assistance.
HI @Bluegrasser
did you try to use the Reset Password option on My Account login page?  Try your email address and see if it send the security code to you
If you are unable to reset password that way, please open ticket with CS agent.
To open a ticket with PM CS Agent. at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
First type: "Forgot log in information"
Then Click "Contact Us"
Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
@Bluegrasser
contact to support team by  CS_Agent  to change email and set new password and update info.
Bluegrasser
Forgot all information to get into my account need to reactivate  my phone and update my account number
@Bluegrasser
Only a CS_Agent can help you access your account.
Probably best to purchase a voucher and call 611 to make a payment while waiting for a CS_Agent to get back to you.
Timer
@Bluegrasser
use browser from computer,and clear cache and cookies and use one page inPrivate mode,
To Login Page
and go to payment,,, manage payment method and update card information and save payment.
you will get verification code by email or SMS
and inserting the 6 digit number and not press anything
just wait a 5 second automatically be login,,
Trouble logging in? then Reset Password as mentioned above @esjliv
@Bluegrasser  -  Are you having difficulty logging into My Account?
If you have created a self serve account and you are having issues logging in, try clearing your browser's cache, or try a different browser or device. Opening a tab in incognito mode may help as well.
If having issues with your password, use the Forgot your password option to reset it, found here: https://selfserve.publicmobile.ca/forgot-password/
You can submit a ticket here for help to: Create or forgot My Account email or password link
NOTE:
