ESIMS for Smart Watches
Dice247
Does Public mobile have the ability to add an additional data plan to an Esim and use it for a smart watch like a samsung gear LTE?
What would the proccess be of aquiring one? Can you just purchase an ESIM through the app and allocate a data plan to it? does public mobile allow to different data plans running at the same time under one account?
Thanks.
2 REPLIES 2
@Dice247
Apple watch requires more system setup on PM side other than eSIM. At this point, no tier 3 provider is offering Apple Watch support even they have eSIM
So, if you need to have data in your Apple Watch , you need to check with Koodo or Telus
JRod
@Dice247
No, Public Mobile doesn’t have any plans or add-on’s to support wearables. You will only be able to have cellular on your wearable when your phone is nearby.
If you wish to have cellular on your wearable when your phone isn’t present you will have to look to another provider.
