ESIM not installed - Stuck on Step 6 of Activation
Spnkr365
Just purchased a plan and activation is stuck on "ESIM not installed" page. I still haven't received a welcome email from Public. I did receive it for my other lines. Chat support is not available. Submitted a ticket - awaiting a reply.
Spnkr365
Checked the SIM settings. No e-sim was installed. Rebooted and did a rest as well just in case but still nothing.
Spnkr365
S23 Ultra. Yep, used the app to subscribe. Usually I get the welcome email which has the QR code to scan for activation but didn't get it. Just submitted a ticket so lets see what happens.
@Spnkr365
there is a chance that the error was there because the Public Mobile esim is already installed and just not properly enabled
On Android:  Check your Sim Card Manager and see if a Public Mobile eSim is there.  If so, make sure it is enabled.
On iPhone: check Settings > Celluar and see if the eSIM is there.  If it is, make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on
If the Public Mobile eSIM is there, disable or delete those non PM sim (eSIM/Physical sim).
If the non-PM sim is physical, remove it.  If the non-PM sim is an esim, disable using the SIM Manager on the phone (or set as Secondary and turn off "Turn on this line" for this non-PM esim)
Then reboot the phone and click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, open ticket with PM support using Chatbot:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗
HI @Spnkr365
what phone do you have ? Android or iPhone?
and you used the app to subscribe?
check your sim manager and see if it is installed already?
if not, since you don't have the welcome email,  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
Spnkr365
Thanks. Was just able to submit a ticket now. Awaiting for a reply and will go from there.
fixin
@Spnkr365 - Please contact an agent here:
⬇️ Click the link for an Agent * ⬇️
If the link above doesn’t work, please go here to create a ticket to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST.  You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for an agent because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
