3 weeks ago - last edited 3 weeks ago by computergeek541
As the title suggests, I am paying for a service which I can’t access.
I have logged into the app and started the process last night. I woke up with no cell service on my ESIM or physical SIM (Telus).
What is the best way to resolve this issue asap?
Would love to chat with an agent
2 weeks ago
An update in case anyone experience a similar issue…
I contacted customer support and had some replies, however I’ve been back and forth since Wednesday with no resolution.
I was told yesterday that it might take another 72hrs to resolve the issue.
I’ve followed all instructions and still have no service. Will give feedback if it’s resolved
3 weeks ago
Thanks computergeek and softech. I’ve followed your instructions and opened a ticket. Hopefully they will resolve by lunchtime
3 weeks ago
there is a chance that the error was there because the Public Mobile esim is already installed and just not properly enabled
On Android: Check your Sim Card Manager and see if a Public Mobile eSim is there. If so, make sure it is enabled.
On iPhone: check Settings > Celluar and see if the eSIM is there. If it is, make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on
if you don't see the Public Mobile esim there, check the Welcome email, there should be a QR code for the esim for you to scan and install manually)
If the Public Mobile eSIM is there, disable or delete those non PM sim (eSIM/Physical sim).
If the non-PM sim is physical, remove it. If the non-PM sim is an esim, disable using the SIM Manager on the phone (or set as Secondary and turn off "Turn on this line" for this non-PM esim)
Then reboot the phone and click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, open ticket with PM support using Chatbot:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗"
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
3 weeks ago
@LP_Public wrote:As the title suggests, I am paying for a service which I can’t access.
Please use the chatbot to open a ticket. https://widget.telus.tiia.ai/publicmobile/publicmobile.html
There's also an option from within the Public Mobile app to open a ticket.
