Didn't received authorization number transfer message
Yuqi11
Didn't received authorization number transfer message, please help @CS_Agent. Old provider is Roger and still active
2 REPLIES 2
@Yuqi11 - WE are not CS_Agents that normally post in the Community Forum. You tagged CS_Agent in your post. Curious did they message you privately to your inbox? If not, you can contact them either 3 ways:
1-click on that hyperlink in your post and click SEND A MESSAGE on the right side, this goes privately to customer support.
2-Normally Faster - use this link to: Get Help With Public Mobile Chatbot], OR
3 -Use this link (same as #1)  Private Message to Public Mobile Customer Support Agents (CSA)
@Yuqi11
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
