Data
Tedk
My account shows I have 2 gig left but I'm getting messages saying I used my data up , I don't know where I stand and no one to talk to
7 REPLIES 7
Tedk
Thanks for the reply , How do I clear cache and cookies ?
@Tedk   which browser you are using? and you are accessing on computer or phone?
generally , for Chrome, click on the 3 dots, then select New Incognito Windows.   A new window will be opened and you just access My Account there
Try the suggestion from Jkurs. The little spinner refresh icons lower down.
Tedk
I have no idea how to do that
Jkurs
I've found that the information on the accounts page isn't updated until you manually do so with the refresh icon under each section.
@Tedk   With this new My Account site, there is lots of problem with caching.  I always use Incognito mode to login to make sure I get the correct updated info from the server
Outdoorsman
@Tedk hi it is possible that you are looking at a cached version of your account data,you need to delete your cache and cookies or use a different browser in private or incognito mode,reboot and sign back in
