Data
cpierce
Will you SIM card work in a Hotspot / Router to provide data
HI @cpierce   Yes, it should.  tested on a ZTE box on my friend's home before
CountyDownIeUk
I use my SIM in a ZTE box for a land line and is very similar to a Smart Hub. So..it does work.
dust2dust
I'm going to pick out your word "in". Yes, you can put the sim in those cell type router boxes like the Telus SmartHub. It will also allow use of the wired phone jacks.
tina9099
I use a hotspot with PM all the time.
Dunkman
Yes, Public mobile support hotspots.
Here is some more information:
https://www.publicmobile.ca/en/on/get-help/articles/mobile-hotspot
RossN
@cpierce hi it should work as a hotspot mine does 😀
