a month ago
Good day. We made the switch over and it was pretty painless.
Noticed a significant drop in data speed as compared to Koodo. Are the public mobile speeds throttled back from Koodo? Thanks
4 weeks ago
@Fishere35 Try both on 4G/LTE at the same time. Sometimes that signal can be stronger than 5G. My iPhone is on 5G auto and still chooses LTE most of the time.
4 weeks ago
The phone on the left is public and the right is Koodo. Today the speeds were pretty similar. The Koodo is still on 4g
a month ago
hi @Fishere35
can you download speed test on both phone and compare the speed. Let us know the actual speed
a month ago
we are still using Iphone 11 (two phones). i had changed my koodo plan to a CAN/USA plan and 5G speed and saw an increase in speed on the phone. i changed that phone to the PublicMobile plan, but the other phone is still on koodo- waiting to change over. i quickly checked both phones this morning and the koodo phone had much faster speeds with both phones sidebyside. i will try again over the weekend but wanted to learn a bit first. thank you for all the comments!! enjoy the weekend.
a month ago
@Fishere35 I get speeds up to the advertised plan maximums although it varies a bit depending on where I am. So unless Koodo allows higher than 250Mbps on 5G then at least here it isn't throttled back any more than it should be as allowed by the plan.
a month ago - last edited a month ago
Is your phone set on 5G in the data settings?
a month ago
@Fishere35 No you should still get the same speeds as Koodo with public mobile
