Data issues
Wodahs
My data is not working today and I haven't received any notifications that I am over my limit so is there an outage on just the data today
@Wodahs
Check this link to see if there is an outage in your area:
https://istheservicedowncanada.com/status/telus/map
There was reports of outage in the Montreal area the other day.
@Wodahs wrote:
It shows that I have used 0.49gb, so the site is either not working correctly or there is issue in my area
@Wodahs call 611 from your device to check the data balance on your account. Your My Account is likely showing cache information.
EDIT:
You could try your SIM into another phone to see if data works.
@Wodahs
Try again  incognito mode/private mode or a different device or lap top or simply try refreshing the page when logged in
and or check
Outage   map in your area:
@Wodahs
did you check using Incognito mode?  If you didn't use it, please check again using Incognito mode.  Some browsers call it Private or InPrivate mode
Wodahs
@Wodahs   the data limit text sometimes is hit or miss
and your voice calls are working?
First confirm your data usage on My Account.  Login using Incognito mode, using that would avoid seeing cached old usage record
If it shows you still have data left, check if your phone has setup any Data limit, Android phones have that setting, please disable it
You can also try changing your phone's Preferred network type or Network mode to 3G only and see if data works
Also, any chance you can try in different area to confirm it is not just a local issue
