Data Add-ons
Kovacsa
Hi All, What are the prices for data Add-ons? Thanks!
13 REPLIES 13
Abby8
In Canada data add on:
200MB- $5
1GB- $15
HI @Kovacsa
and final thought, if you need to port, your account with the old carrier must still be active
for sim, you can use esim, or you can use physical sim card, you can buy physical sim during activation, but please choose pickup from store as that is more reliable (or faster) then wait for PM to ship the sim card.
Good luck and see you in PM soon 🙂
Kovacsa
For sure!
@Kovacsa  You may want to pull the trigger sooner then later on that plan . As the Boxing Day deals are set to end tomorrow .
Welcome to PM, @Kovacsa
remember to apply a friend code during activation to save $10
Kovacsa
I'm not with PM atm, but will be soon.
@Kovacsa wrote:
I don't use much data, 4GB plan should be enough for the moment
hi @Kovacsa you are already on the $24 plan?
if not, try your luck and ask PM support agent to change you to that, many have luck changing over
Kovacsa
hi @Kovacsa
you probably know the price by now.
Remember, data add-on has a 30 days life, so, don't over buy
and if there is a chance your current plan's data will not be enough month after month, consider changing to the better plans with more data.  Many able to change to the boxing day plan , even though saying for new activations only.
Chalupa_Batman
Clearly you've received your answers. However, truth be told, it's better to pay for a 5G account that has a large data amount with unlimited data. Refresh my memory, which plan did you end up going with?
cellphoneuser1
@Kovacsa $5 for 200MB and $15 for 1GB
TheSterlinger
The prices of the add-one are listed on the subscriptions page in shop. Scroll all the way down and click add-ons to see the add ons and the prices.
@Kovacsa  note all data add  on now expire  30 days after purchase . So might be best to upgrade plan instead . Just a thought
