Dark Pattern
Stolk
Public Mobile is using Dark Patterns.
Adding an add-on is easy, but they provide no apparent way to remove one.
how can I remove my extra data option?
7 REPLIES 7
Stolk
yes, you are right. Not so dark now.
having to make a forum account and having to go through chat bot to open a ticket, definitely is though.
dust2dust
This is the second time I've seen this term so I had to look it up. Not so dark now eh 🙂
Adding - this is one of two of the big 3 main providers and their sub-brands that have add-ons that stay on the account after initial purchase. The other is Koodo. Both Telus. None of the others do this. The add-ons drop at the next renewal if not fully used.
MrSpock
@Stolk add-ons don’t automatically renew but it does stay on your account until this is all used up you won’t be charged for it twice
Hi @Stolk all addons are one time purchase,  won't automatically reapply
post a screenshot and explain more
Stolk
You misunderstood
I do not want a refund.
i just want to stop the add on.
the fact that it is automatically re added is another dark pattern.
MrSpock
@Stolk Hi there is no way to remove them unless you bought one by accident and haven’t used any of it yet you can contact customer service agent to open a ticket, to speak to a customer service agent    Click here or if you are having issues with Simon you can send private message to a CS Agent here:  https://bit.ly/2GGCJzH
@Stolk PM is prepaid and usually no refund
but open ticket with CS agent to discuss
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. start by typing : Contact CS Agent
  2. then Click "Contact Us"
  3. then Click "Other"
  4. finally Click "Click here to submit a ticket"
