Could not activate Cellular Network IPhone 4
insaneHoshi
Hey.
I am unable to activate data on my iphone 4 running IOS 7.1.2.  I have done a factory reset.
Researching the topic, i have been pointed to this page (http://productioncommunity.publicmobile.ca/t5/Announcements/iPhone-Update-and-APN-settings/m-p/1610#...) to modify my APN settings, but on my iphone, these seem to be unavailable.
Any Advice?
@insaneHoshi
Glad to hear that your issues been resolved
** I am not a Mod, please do not include any private info in a private message to me.**
insaneHoshi
The above solution worked, thank you for you assistance.
srlawren
@insaneHoshi were you able to get your data working using the suggested method?
Also have a look at this link
http://productioncommunity.publicmobile.ca/t5/Discussions/Data-will-not-work-with-Iphone-4/m-p/61284
Also this
http://productioncommunity.publicmobile.ca/t5/Phones-Hardware/iPhone-4-3GS-3G/td-p/13467
Phone 4 APN settings cannot be updated manually. You will need to connect to wifi, access APN iPhone 4 with Safari, then follow the directions there.
mimmo
IPhone 4 is a special case. From what I remember you need to go to a website and load the Apn settings through a file or something. Will see if I can find the details.
http://productioncommunity.publicmobile.ca/t5/Discussions/APN-setting-with-iphone-4-ios-7/m-p/54513#...
