Could anyone advise the steps to port my AB number?
wzhong
I will move AB to ON this weekend. Thanks!
7 REPLIES 7
wzhong
Super and thank you very much!
mimmo
@wzhong  there are some options to do this.    is there a reason you want to have two numbers?  I woudl probably just keep your alberta number and skip the ON number all together.  or I would sin up with Fongo and get a free VOIP  Ontario number and install their app on your phone.  then you will have two numbers on your phone.
JK8
@wzhong wrote:
Thanks, so I do need to switch AB phone number to ON phone number. Does that mean I need a new SIM card? Thanks again!
No new sim card just go into self service to change your number. You can change your number up to 4 times every 30 days.
wzhong
You can only have one phone number per account and sim.
wzhong
Oh, I see. My current PM phone number will move from AB to ON. Is it possible to keep AB phone number and same time to get a ON phone number? Thanks!
mimmo
@wzhong  what exactly do you want to do?  Porting is going from one provider to another.  It's a completely different process than changing numbers which I believe you might want to be doing?
Edit: this is a good read and should answer most questions.
https://www.publicmobile.ca/en/on/get-help/articles/port-fraud-protection
