2 weeks ago
I changed to service provider. But public mobile service Continuously charging. I need help to stop charging and those charges already taken to get back.
2 weeks ago
The only way to stop Public Mobile from charging you is to toggle off the subscription status in your self-serve or successfully port your number from this service to another provider.
If you didn't do either of those, the service will continue to bill here, as it should.
2 weeks ago
@Imam12 The chatbot is at the chat/message icon bottom right of this page.
Did you port your phone number fo another provider? That should have closed your account if successfully transferred.
2 weeks ago
Where’s the chatbot for open a ticket
2 weeks ago
Please open a ticket using that chatbot fo discuss this with a Public Mobile customer support agent.
