Community
SweetP
I used 1/4 of my data in one day. Never ever did that before?
SweetP
Thank you, I’m going to check it out right away.
@SweetP
Phil_Adelphus
@SweetP  What plan do you have?  The $15 plan, for example, has 250mb which is not much these days.  There are changes you can make to settings to minimize data use and you can also see in the phone settings which apps have been using cellular data.  If you have an iPhone turn off WiFi Assist, also turn off data altogether except when you need to use it.  If you have a plan with more than 250mb could you have done a speed test?  At the higher speeds the tests use a great deal of data.
HALIMACS
@SweetP
The first question might be, which plan you are on.
And ensure you tap the little refresher icons on the self serve page to get an uncached version of the information.
 You may be viewing outdated information.
SweetP
Thank you, I did check my usage but didn’t refresh on my phone. Where do I find incognito/ private mode, I have an iPhone
@SweetP  It happens but you can double check like this for your usage
Try again incognito/private mode
And or lap top /computer
                    OR
simply try refreshing the page to check data plan / mins / add ons
