12-13-2021 03:18 PM - edited 01-04-2022 04:51 AM
Hi all,
Is there anyway to see where you currently rank in community awards or is it only at the end of the month if you get a reward?
Thanks
12-16-2021 03:25 PM - edited 12-18-2021 02:27 PM
@softech wrote:
@darlicious wrote:when you give a bravo then others are more likely to bravo you.
That certainly works well.. We can find many "good friendships" on the community.. look at their bravos count with each other.. 😂
Oh yeah, wish I had a very dedicated follower or two who made sure to always give my posts a bravo no matter if the posting is relevant to the question or not! 😁 But I guess that's not considered gaming anymore?
12-16-2021 09:16 AM
Welcome to PM, try and be as active as you can and see where you rank at the end of the month. You can use that to gauge how many posts and solutions you need to maintain or go forward with the next month.
12-15-2021 03:21 PM - edited 12-15-2021 03:26 PM
12-15-2021 03:18 PM
Posting increases the chance for you to recieve a bravo and like gift giving when you give a bravo then others are more likely to bravo you.
12-15-2021 02:45 PM
Does giving bravo and posting increase the chance of rewards?
12-15-2021 01:19 PM
If it can help, you can see how many people were rank top 50% for example. It kind of gives an idea for the ranking.
12-13-2021 06:04 PM
The community rewards are based on your contributions each month and the formula is based on your posts/bravos/solutions totals. You can track your own progress each month by following your stats by way of how @esjliv mentioned or in your community profile.
I personally keep track of approximately 100 regular contributors and feed the stats of the top 25 members into the Univac 5000 to calculate the best estimation of where they will land when the badges are handed out. Due to the age and outdated technology of the Univac 5000 and the ability to obtain replacement parts the very unscientific results are fraught with errors so really its just a best guess.
There used to be a bravo leaderboard to follow but it was removed to discourage competition among fellow members. Here are your current stats:
12-13-2021 04:57 PM - edited 12-13-2021 05:05 PM
@Bfdarby wrote:Hi all,
Thanks
@Bfdarby - the badges are awarded normally around 10-14th of each month for the previous month. These badges are awarded the same time the Monthly Announcement is made...should be soon now, I would think.
If you were awarded Community Awards you will see the $s listed under your Self Serve account, and you may also receive a notification in your Community feed about a badge.
If you hover over anyone's Community User name, then click their "View Profile" you will see there current and past Community awards if any were given for that particular member.
12-13-2021 03:59 PM - edited 12-13-2021 04:00 PM
12-13-2021 03:59 PM
12-13-2021 03:27 PM
@Bfdarby No, you won't know your progress compare with others during the month. So, just do your best and let PM surprises you
12-13-2021 03:23 PM
Thanks
@Bfdarby You'll get a notice towards the end of the first week of the month (usually) saying what, if applicable, you earned in Community rewards. It usually requires some active participation, either daily or couple of times a week to be eligible to receive any rewards.
12-13-2021 03:21 PM - edited 12-13-2021 03:22 PM
Thanks
It's a secret until rewards are announced at beginning of each month. Just keep contributing when you can and you might be rewarded too.
