10-23-2022 05:59 PM
I'm trying to login into self serve and when I try to change password to new one it gives error code I need to login to add money to my account
11-02-2022 02:58 PM
@Luddite- One can use direct urls to get to some of those functions when suspended. Have I tested them then? No. 🙂
11-02-2022 02:51 PM
@brandon118661 Just wondering if this was your situation.
Suspended account
SO to regain full acccess one must reactivate first
10-23-2022 06:13 PM
Another method to pay is using the real time payment system in some stores.
If you know your 4 digit account pin you can dial 611 to make a payment. Vouchers in 611 don't need the account pin.
10-23-2022 06:04 PM
@brandon118661 hi try clearing your cache and cookies or use a different browser in private or incognito mode reboot your device and try again if problem persists
you need to contact a customer service agent to reset or change your email and password
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
10-23-2022 06:03 PM
Until you can get the password fixed, funds can be added to your Public Mobile account by dialing 611 (if you have a credit card saved there or if you have a voucher).
As for the password reset, trying doing it using private/incognito mode in your browser.
