05-06-2024 11:45 AM
Is my call, text and data plan that I have now good in the USA as is or do I need to buy additional USA text/call/data. My plan is $34/month 50GB Canada -USA
05-06-2024 11:50 AM - edited 05-06-2024 11:52 AM
@Gotzz once you have a Canada-Us plan, you don't need to purchase anything else. Just need to turn on roaming when traveling and have VoLTE enabled phone.
Service can be used equally in both countries sharing data and calls.
05-06-2024 11:49 AM
HI @Gotzz
if you have Canada/US plan, then you can use data and make calls and text in US, no extra raoming addon needed. You can make calls in US to any US or Canadian numbers.
but on your phone , you still need to turn on Mobile roaming data and make sure you connect to either T-Mobile or AT&T
