Cant send pics in text
Hofft4849
Help
CountyDownIeUk
If you have an iPhone and are used to iMessaging pics......it’s different to text a pic to an android phone as mentioned....turn data on.
popping
Picture message need data  to send and receive.
If you mobile data is enabled and still cannot send and receive picture message, check the APN settings is correctly configured.
If you are using a LG phone, you need to reset the network setting before you data working again after changing mobile provider.
If you are using an iPhone and cannot send/receive picture message without WiFi connection, you need to enable the SMS/MMS settings under the iMessage app settings.
hycm53
@Hofft4849  You need turn on cellular data on.
noaccountpls
@Hofft4849
Make sure MMS is turned on in your phone setting this setting is usually under the messages tab under your main settings of your phone depending what type of phone you have I hope this helps.  If the settings were turned off turn them on then restart your phone problem  should be fixed the same steps to work for iPhone to settings messaging turn on MMS and send by SMS
RossN
@Hofft4849 hi your data needs to be enabled to send or receive picture texts/mms
