11-24-2022 06:54 PM
I have a active mobile number but cannot get into my account to change plan cant seem to actually talk to someone isnt there a number to call costumer service? And when I press *611 it says I ha e an account balance of almost 70 but every month they say I need to put funds on my account. My cell is a pay as you go and all I seem to have is more and more problems and cant seem to get any where with this site. My God isnt there someone that I can actually call and get this figured out
11-24-2022 07:05 PM - edited 11-24-2022 07:07 PM
@Venessateddy wrote:I have a active mobile number but cannot get into my account to change plan
Try clearing cache and cookies, opening an incognito tab, then trying again.
Public Mobile is an online only mobile service provider - this is made very clear at every stage of service.
Every month, Public Mobile sends reminder texts just to remind folks of an upcoming renewal. Some folks might not have a credit card registered and have to place funds in the days preceding renewal. This reminder text helps ensure they don't suspend on renewal.
Public Mobile is not a "pay as you go" model. It is a pre-paid service. There are no contracts. Can you tell us, specifically, what might be the issue you're trying to get resolved? If you're just trying to change plans, when on the self-serve page, click Plans and Add-ons to the left, then select the 3g or 4g plan you prefer, then change on next renewal.
11-24-2022 06:57 PM
did you try to reset the password using Reset Password there?
If it does not work, you will need to open ticket with CS agent and they will help you to reset
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
If you are really rush to put in money, you can also go and buy a voucher and then load the voucher using *611
