08-12-2023 06:02 PM
Hi,
I received my new simCARD but cant login to my account. Keep saying that code is wrong....25 times code was resent, still wrong code. What is going on?
08-12-2023 06:05 PM - edited 08-12-2023 06:05 PM
@RPropost Try the I didn’t get code option or resend code . Won’t give you option for code be sent to email instead ? If no luck please submit ticket with support to help you regain access
private message To CS_Agents click
VVVVV Link below VVVVV
08-12-2023 06:03 PM
HI @RPropost
you are using the app? try uninstall and reinstall the app
still not work, please submit ticket with agent here:
